spec clutch noise
spec clutch noise
i have a spec stage 3 with the billet steel flywheel and it squeaks....is this a normal thing for a spec clutch?
Carbon-semi-metallic based disc materials can have some sound during engagement. The amount of sound and frequency of its occurence are greatly dependent on the amount of slip induced when engaging the clutch. The more you drag your foot the more apt you'll be to have this noise. Also, flatness of the flywheel can contribute to this as well. That being said some noise of this kind isn't unusual.
