Clutch or Syncro's
Old Feb 19, 2010 | 11:11 AM
Alpha-Q's Avatar
Default Clutch or Syncro's
95 Z28 6 speed. My car use to grind when i chaged gears. The grinding is still there and now it pops out of gears (1st, 3rd and 5th)
Anyone know what can be the problem?
Old Feb 19, 2010 | 11:13 AM
bigj2717's Avatar
If its grinding going into gears it more then likely the syncros
Old Feb 19, 2010 | 11:17 AM
Alpha-Q's Avatar
^It's not grinding going into gears, it's grinding when i shift at high rpm. For example, if i shift around 3000 or 4000 rpm then it grinds. If i shift at 2000 rpm it doesn't. It just pops out of gears.
