popping out of 6th
popping out of 6th
My transmission on my Z06 Corvette is physically popping out of gear when you try and accelerate. All other gears work great, including 6th, it just pops out under load. If you hold it in it works. Any idea whats wrong?
i havn't no. I just bought the car 10 months ago and parked it for the winter 7 months ago. So I've only put 2500 miles on it. The car has just about 100,000 miles on it tho.
100k miles if it still factory fluid, its over due. When ever I bought a car, wat ever the last owner told me, I change it out anway, drain the fluid out the put in new fluid, hope you dont see any peice of syncro coming out. if it does, its a very bad sign.
K so if I take this whole tranny apart tho, do I need a whole new synchro or can I purchase like a synchro gear, or is there such a thing? Anything else that I would need while it's apart?
On Corvettes, the diff is attached to the trans. It will be a major undertaking (need to remove the rear cradle to remove the trans/diff together) to do this yourself. Have a shop do it for you unless you have done this before or mechanically inclined.
