McLeod master question.
Old 05-08-2010, 11:25 AM
bayer-z28's Avatar
Default McLeod master question.
I've had a McLeod single with the master in my car for quite some time now. My pedal is quite high. if I adjust the master to sit lower, will this effect the disengagement? I adjusted it so the clutch disengages 100% and had the peak of the clutch feel around the middle of the throw. The stock master wasn't disengaging the clutch all the way.
How much pedal travel do others have here?
Old 05-09-2010, 10:10 PM
FirebirdStud's Avatar
I actually had to adjust my pedal down to get full dissengagement. My clutch is just a touch lower then my brake pedal now. I put the car on jackstands, put the clutch all the way in, put it in first, and reved to 6500rpms and the rear tires didn't move. Perfect.
