Monster Clutch Level 4 question
Old 06-14-2010, 06:35 PM
Quick SSilver 98's Avatar
Default Monster Clutch Level 4 question
Ok I am thinking about getting the complete package from tick performance. Tick Performance & Monster Clutch Level 4 Complete Package (775hp/tq). I was wondering how much harder my clutch pedal would be to push down with this clutch? I daily drive this car so I dont want a super stiff clutch pedal. Also Is the monster clutch level 3 softer than the level 4? I also plan on getting the 18LB Lightweight Flywheel. Any feed back on either of thes products would be greatly appreciated, Thanks.
Old 06-14-2010, 08:21 PM
tyler ovel's Avatar
Ok i got the level 3 and i love it. before i bought it i was deciding on the level 3 or 4 and i read on hre that the level 3 will last a little bit longer than the 4 because of its sticker compound that the level 4 has. The pedal is not stiff at all but i did get the 28lb flywheel cuz its more of a stock wight for a flywheel which should make it feel more stock from what i understand. pedal is bout 10% harder and thats it. great daily driver and strip clutch !!! do more reading on here and make your decision on what stage to get. i know that the level 3 is the most popular clutch they make good luck
Old 06-14-2010, 08:47 PM
gmmusclecarman's Avatar
I have that exact setup and my clutch pedal is stiff but not too stiff. Its perfect, its stiff enough to give you a great feel but not uncomfortably stiff.
Old 06-14-2010, 08:54 PM
sciff5's Avatar
So far I've driven a spec 3+ an oz700 and now I have a monster stage 3 (same pressure plate as the 4 so it shoul have the same pedal pressure) and I like the monster the most.
Only clutch I liked more was a mccloud twin disk. I learned to drive on a h/c SS with a mccloud twin, to give you an idea of how easy it was to drive.
Old 06-15-2010, 09:54 AM
Thanks for the info guys. I think i am just going to go with the stage 3 I really dont think this car will ever see 700+ RWHP Maybe 600 with a shot of nitrous someday.
Old 06-15-2010, 10:28 AM
sciff5's Avatar
If you arent leaving the line hard, and the car is not a heavy weight, that will really help keep stresses on the clutch down.
I know the monster stage 3 gets the local gto guys about 1.5 60's pretty consistently and they are 3800-3900lbs although they are only pushing about 550whp
Quick Reply: Monster Clutch Level 4 question
