AutoZone duralast clutch kit, look at pics here.
Old 06-15-2010, 09:52 PM
TROPIC_THUNDER's Avatar
Default AutoZone duralast clutch kit, look at pics here.
The PP says VALEO. the clutch says Raybestos. I am not using the clutch.
What is the best clutch to match up with this PP for a 97 trans am.
Only boltons and full exhaust.
Do i get a Organic or kevlar or ceramic.. Thanks
I need to get the setup balanced right??
Old 06-16-2010, 01:09 AM
BALLSS's Avatar
McLeod makes a DF disc # 260571 IIRC
http://www.jegs.com/i/McLeod/673/260571/10002/-1
organic/ceramic disc
Old 06-16-2010, 10:57 PM
thanks
Old 06-17-2010, 09:15 PM
crainholio's Avatar
That's an LT1-type pull clutch anyway, won't work w/ an LS1 running factory type hydraulics.
Old 06-17-2010, 09:29 PM
draggin97s10's Avatar
he said 97 TA.
Old 06-17-2010, 09:40 PM
crainholio's Avatar
Originally Posted by draggin97s10
he said 97 TA.
I guess I forgot this was LT1tech.com or something.
Old 06-17-2010, 09:51 PM
JP
JP's Avatar
Originally Posted by crainholio
I guess I forgot im a douchebag or something.
dont be so hard on yourself
Old 06-17-2010, 09:58 PM
crainholio's Avatar
Originally Posted by JP
Call me for a good time.
No thanks, I'm straight.
Old 06-18-2010, 10:04 AM
LOL. you guys get butt hurt awful easy
Old 06-18-2010, 10:07 AM
Billy M's Avatar
Actually it's a 261571 for the pull type LT-1. The 260571 is for a conventional push style pressure plates.
Old 06-18-2010, 11:17 AM
BALLSS's Avatar
thanks Billy....the drop down menu on Jegs list 260571 for 67-97 "camaro"...go figure.
so is the "261571 a DF disc??
Summit list it as "organic"
so is it a organic/ceramic disc?
McLeod site come up zero with the 261571..
http://www.mcleodracing.com/search/default.asp
Old 06-21-2010, 10:41 AM
Billy M's Avatar
Yes it is a dual friction disc, organic ceramic. It fits all 1993-1997 pull style pressure plates. I have updated the website to reflect the correct info.
Old 04-08-2011, 09:32 AM
AR15 guy's Avatar
Which part number was the kit? Would the Autozone PP, bearings and a McLeod disc be better than a Ram HD setup or a Spec stage 1?
Old 04-08-2011, 09:56 AM
Build #1's Avatar
A buddy of mine ran consistant 7.05s in the 1/8 with an autozone clutch. To this day i still wonder how. It may have been slipping but you couldnt tell by him picking the front wheels all the time. It was a LT1 car that soon got a powerglide and instantly ran 6.80s.
Old 04-08-2011, 11:15 AM
riceburnerZ28's Avatar
your friend must have been lucky cause I burned up my stock autozone clutch in under 3k miles with only one short burnout
Quick Reply: AutoZone duralast clutch kit, look at pics here.
