Need some help with some bolts I am looking for the two bolts that hold the slave to the mid plate and the bolts that hold the transmission to the bellhousing. Anyone know who seels these or what size they are? Thanks |
Try this: Transmission to Bell Housing Bolt M12 X 1.75 X 45mm GM p/n 22649722 Slave to Transmission Bolt M6 X 1 X 26mm GM p/n 11516424 |
Trans. to bellhousing are M10x1.5; I have some of these (basically identical to OEM; I had to buy 50 I think) if you want 'em. |
2 Attachment(s) Hmmm...seems to be several part numbers floating around for the transmission to bell housing bolts and some threads claim they are interchangeable with the bell housing to engine bolts, but not according to my parts cd. Here's the 2nd part number that matches up to what JMD is listing for the correct size foir what you are looking for: Bolt M10 X 1.50 X 40mm GM p/n 14050422 Which also seems to be similar to GM p/n 12523235? The thread I found talking about the 2 part numbers above are interchangable and can also be used for the bell housing to engine bolts, but the difference may be the size of the head which could cause fitment issues? |
Thanks for the help guys. M12 and M10 are sizes of the shank not the head. I think i have extra bolts that hold the main case to the midplate so i will see if those fit. |
© 2024 MH Sub I, LLC dba Internet Brands
