What RPM to launch T56 at the track? My 89 has a Trex cammed 6.0 with the 6 speed, 4.30 gears on 26x11.5x16s and i launched at 5100 an bogged a touch and got a 1.9 60 foot, some are telling me too launch at 6000 but i was scared of breaking the trans, now that 2nd gear is gone from playing on the street i will be going back to the track when i get the trans rebuilt and i need to know what you guys launch at. I have a centerforce DFX clutch if it matters. |
If the trans cant take it then?? I thought mine was up to it and now another 2800 (with new drive shaft) later it will be. |
If you have a good driveshaft, a good torque arm, and something better than a 10 bolt with sticky tires I'd lauch it off the rev limiter.... |
let it fly man. 6k with a good set of tires |
No personal launch preference from you guys rides? I have a moser 12 bolt and the trans will be built soon, stock LS1 driveshaft. |
Gonna have to get a real DS....that stocker becomes the weak toothpick after you get a good clutch and rearend. Once you get those....like Jonathan said....off the limiter! |
Originally Posted by Jonathan@Tick
(Post 13726068)
Mine was a trans from SSI 4a and I have a 12 bolt also(moser). On a good track I launch at 6000. a poor track around 4500. But depends on my tires,weather etc. I disconnect my swaybar for the track and loosen my shock settings for the track. If it bogs on launch I hit it harder next round. As close to same spot I launched the round before. |
get a good driveshaft, and let her go off the limiter. |
Originally Posted by cody161
(Post 13732053)
get a good driveshaft, and let her go off the limiter. OP, Im assuming your car weighs much less than a fully optioned f-body so that should help it stay alive for a while. |
No man....that stock DS will snap with ease. It will be ok on the street, but not at the track with a serious launch with a decent 60ft. Or making any power. |
I launch around 5k-5500. Stock trans with ls7 clutch kit, fab 9" with upgraded driveshaft. Best 60' so far,, 1.59 |
12 bolt is now a weak link too, if you race alot, and launch high, it's not going to last. I launch at 6500, and cut consistant 1.42-1.44's, but blew up the 12 bolt 3 times... Nine inch stays quiet and takes the abuse like a champ. 12 bolts are fine in auto's for the most part, and 6 speeds that dont race alot. The trans however, will take alot of abuse, although I did twist an input shaft. |
That is true....damn TQ. arm mounts the same way, most end up ripping gears out like a 10 bolt. |
i launch at 5500 -6000, have a moser 12 bolt and cut 1.4s on a 4.10 gear, havent broke the rear yet. but definatly a new ds. i run a monster clutch so i dont know anything about how well the centerforces are holding on high rpm launches |
Alright, so i should put it off till i get a DS, that sucks since it is not in my immediate budget, building 2 cars really hinders the cash flow...dammit. |
Zane, I have a couple pics I'll post up of my drive shaft that shreaded in two and I didn't even make it out of the burn out box. |
Yeah my Nitto DRs only held a 4000rpm launch or so on motor at the track a month or two ago. Once I get some QTPs its 6000 on the 150 hit and let it ride. |
26" tires and a 4.30 gear should put your launch rpm around 6000-6500 rpm |
© 2024 MH Sub I, LLC dba Internet Brands
