LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Manual Transmission (https://ls1tech.com/forums/manual-transmission-14/)
-   -   Need Help, Car won't start (https://ls1tech.com/forums/manual-transmission/1323711-need-help-car-wont-start.html)
Dr Tran Aug 28, 2010 08:41 PM
Ok, first off I'm not sure if this is where I should put this thread, but as it's partly clutch related I figured why not :lol:
Ok, so the car won't turn over. I check for:
Battery Voltage: 12V
Starter/Ign Relay: Good
Constant Power at Starter: Good
Trigger Wire on Starter Solenoid: absolutely nothing when cranking
Vat's light does not come on, and the fuel pump runs.
So I am thinking it is either the Clutch safety switch or the Ignition switch. What I am wondering is if anyone has the wiring schematic for the clutch safety switch so I can bypass to to eliminate that as a problem. The car is 00 M6 btw.
Steve Gunn Aug 28, 2010 10:31 PM
Clean the key fob or try another key.
Dr Tran Aug 28, 2010 10:37 PM
I tried my spare key, it didn't work either.
© 2026 MH Sub I, LLC dba Internet Brands
