Doing a t56 swap from 4l60e, couple of questions
t56 out of a 94 camaro is going into a 97ws6 trans am
which harness should i use
i cant use the ecu out of the 94 cause its obd1 and my car is obd2
will the harness out of the 94 work just fine or do i have to use the harness that is in the ta right now.
also what all needs to be done if i use the harness out of the 94 camaro.
Thanks
Alex
Thanks
Alex
if you look in the "M6 to A4" sticky at the top of this page, youll see on the very first page is a word document walkthrough for the LT1, tons of info in that thread, but its got all the wires that need to be spliced and everythihg. its in one of the stickys at the top of the page.
I wouldn't do the wire splicing, and re-pinning the PCM. That is very tedious and it is very easy to make a mistake. I've done a lot of these swaps and it was always easier to just swap the PCM and entire under-hood wiring harness. Basically, it would be best to stay OBD1, and use a 1994 or 1995 M6 harness. Good luck with it!
This is of course depending emissions regulations enforcement where you live.
