Textralia / QuickTime Bellhousing Install Pics
Old 10-10-2010, 09:58 AM
SweeTbone's Avatar
Default Textralia / QuickTime Bellhousing Install Pics
Just got wrapped up with my Textralia Z-grip, Quicktime Bellhousing, Tick Adj. MC install. Everything went together pretty smooth. Stock MC was a little tough to get out and lining up the trans took about 10 minutes, but with a lift and all the proper tools it was bearable. I've been rockin' the stock clutch for 3 years on my current H/C/I setup, so I haven't been driving it uber-hard, but now I'm set. Only put about 25 miles on it so far, but everything about this clutch is rockin' my socks. NO chatter or nothing. On to some pics...
This stocker is ugly as sin.
Stock bellhousing off.
This factory clutch was pretty beat down. There were burnt piles of dust and decay everywhere.
Old garbage slave. It's seen some work.
Puck yeah!!!
Flywheel up.
Test fit the QuickTime Bellhousing before the clutch goes in.
Motor plate went in fine too with no grinding anywhere. I had read some people had to grind the oil pan a little, but it was all good here.
Stock MC vs Tick Adjustable. The stocker was a BITCH to get out, so you can see we just bent the rod to get it out.
New slave and remote bleeder.
Everything bolted up. Awaiting the trans.
Old 10-10-2010, 10:43 AM
1nastyss's Avatar
Looks like u had some good luck with the Bell housing, im getting a little more confident with the fittment....Looks good
Old 10-18-2010, 11:38 PM
Zmg00camaross's Avatar
I probly will be getting one of these. Looks great and Guess its just bolt in no dial indicator and measureing to center it up and shimming the clutch? And Who has the best prices on these things. PM if you like.
Old 10-19-2010, 01:45 PM
Internet Mechanic
BlackScreaminMachine's Avatar
Quick Question, are these SFI rated?? Also can they handle a clutch explosion?
As for the clutch, your going to love it, its a killer peice. If I broke my trans today, if the clutch looked fine, Id toss her right back in!
Old 10-19-2010, 06:24 PM
SweeTbone's Avatar
Originally Posted by SweeTbone
SFI SPEC 6.1 . Shot of the sticker on the bellhousing. It's right above the date of manufacturing. It will contain an exploding clutch for sure.
Old 10-19-2010, 06:40 PM
Fr8Train's Avatar
looks good trevor!..represent the fbodys on mondays track day!
Old 10-20-2010, 07:38 AM
Internet Mechanic
Sweet, then this is a great piece. I know I will be doing that install this winter.
Old 12-04-2010, 01:17 AM
cowboysfan's Avatar
any issues since install?
Old 12-04-2010, 07:18 AM
SweeTbone's Avatar
Nope, not a thing. I really wouldn't expect any issues once it's installed. I've put about 300 miles on this setup with zero problems.
Old 12-04-2010, 07:45 AM
bayer-z28's Avatar
Had fun tanking the master OUT???? No mention of the swear-fest putting it back in.... That has GOT to be one of my LEAST fav jobs to do on these cars..
Quick Reply: Textralia / QuickTime Bellhousing Install Pics
