HELP!!! Throw out bearing or pilot bearing maybe?
What's up guys been a long time since I posted. I took out my t/a to jersey this past week came to a toll booth pushed clutch in put car in neutral but held clutch in. I heard kinda of rattling with a squeaking noise. I let the clutch out and noise stops. After I paid, I push the clutch in tried to put in 1st. It didnt go to 1st or any other gear. After couple minutes I shut the car off, then went into gear no problem. After that I was able to drive it an hour and a half home to connecticut with no problems. Once I was movin I didn't use the clutch and at lights I put in neutral with clutch engaged. Currently everytime I push in the clutch and it makes that rattling/squeaking noise. The clutch still feels great not spungy or nothin.
Beginning of last year I bought and had installed a rebiult t56 tranny. I had put in new clutch master w/ drill mod. New slave all parts from gm. New centerforce clutch(luv it!) new fluid, new flywheel.
I read a bunch of forums and Im thinking pilot bearing and/or throw out bearing but I desperately need advice!!!
It could be the throw out bearing. Im just saying Ive had a few go out and they always stopped making noise when I pushed in the clutch. And the way a pilot bearing works it seems it would always make noise no matter where the clutch is. Maybe somebody else that knows more about it will chime in. Either way you got to pull the tranny.
My pilot bushing recently went out and it made whirring whirring noises between shift or any time the clutch was being used. Also felt like something was spinning off balanced when the clutch was being used. It was the tip of the tranny and the clutch disk getting stupid as a result of not being properly captured by the pilot bushing.
A busted TOB makes a grinding noise when it fails.
Sounds like the pilot bearing. If it is, check your input shaft end play. If it moves up and down at all, the trans needs to come apart and shim the input shaft tighter. It will wear out you pilot bearing prematurely.
