Best TraNS Fluid for T-56
My t-56 has about 153k miles on it and about 10k on the fluid, it has royal purple in it now, im gunna change the fluid this winter, what do you guys recommend? One of my buddies swears by gm synchro-mesh but the royal purple i got was suppose to be same stuff half the price. Also doing rear-end fluid, I know theres a seperate section for gear/axel but I figured Id kill two birds with one stone. Im running 75-90 GL-5 with a posi additive right now. Any opinions on what might be a better choice? Thanks guys.
amsoil, no questions asked. been running in my T56 race car for 3 years now, with ZERO trans problems. I just change it before each season.
https://www.amsoil.com/storefront/atf.aspx
what year is the T56? has it ever been rebuilt?
I think the synchromesh is bad for the paper blocker rings that came stock up until 01' or so, but I like the feel of synchromesh a LOT better than the Dex III I had first
I had Mobil 1 synthetic, liked it but discovered that I most likely have the paper blocker rings. I switched to Citgo Dex III, doesn't shift quite as nice as the Mobil 1 but the slippery synthetic fluid is a lot easier on the paper blocker rings (they basically function off of friction) than the synthetic.
EDIT: BTW, when I say it doesn't shift quite as nice, I don't mean that it shifts bad at all. Still feels good, almost more smooth instead of as easy.
It is a 99 and as far as i know has never had any work done, just turned over 153k this week. I have some shifting issues as well, hard to get into 2nd and 3rd at high rpm, I put a tick perf master cylinder in it and this seemed to help but did not fix the issue, also pops out of reverse alot. And grinds into 4th at high rpm, I was told the royal purple would solve most of my shifting issues, it did not, and then the master cylinder was suppose to be the key, it was not. Im no trans expert but I would venture to guess that my synchros are bad possibly?
exactly what i use. smooth and safe for your blocker rings. i tried the MB1 ATF and it felt fast like shifting in water, a little notchy but i didnt mind. i got paranoid because of the stock blocker rings and went back to STD Dex 3 and its def smoother but slower like shifting in thick oil.
