Correlation between Tick master adjustments and clutch slipping?
Hello all-
This may be a potentially obvious question, and I may have remedied it, but I figure I'll ask here before I go to the track next week.
Background Info:
After taking my car out of hibernation two weeks back, I felt what seemed like my clutch slipping a tiny bit. I at first attributed it to cold summer tires, but it happened twice yesterday, and quite bad at that. I also then noticed that my clutch was picking up even from resting my foot on the pedal, so my instinct was to wake up this morning, and adjust my Tick Master. Now, my clutch is fairly new and is a stout piece, and the tick master was adjusted last year by yours truly. Car is not daily driven, nor has it yet been to the track with this setup.
Questions:
Would a tick master being out of adjustment cause a clutch to slip? Is it normal or a clutch to require adjustments from the Tick master so often? And if so, is that because my clutch is such a heavy duty item?
Thanks all for your time.
The Car in question:
Background Info:
Questions:
can the flywheel get some surface rust from sitting like a brake rotor and cause some slipping until it wears off? seems like it would wear off really quickly but who knows. or could the clutch just be slightly glazed? not sure on those
but as far as adjusting the tick, I think if you adjust it too far out and overextend the pressure plate it can damage it and possibly reduce clamping force
Before, up top. Now, it is more towards the middle, but the amount of throw is tiny. Before I adjusted it, the pedal was only slightly below the brake pedal. It is now much closer to the floor.
When my car sits for a little while in colder temps, the engagement on my clutch goes down like your describing. After driving it a bit to warm everything up, it goes back to normal. I think that is typical stuff with hydraulic clutches. I haven't noticed any slipping though.
edit: I have a Tick master
