99 camaro ss Clutch Master Cylinder
I have the notorious Clutch master cylinder issue, after accelerating full throttle thru 1st and 2nd gear or any gears for that matter the clutch becomes soft. Will replacing the master cylinder with a factory master cylinder solve my problem for at least the next year (the car is completely stock) as I plan to eventually sell the car? Or will this began occuring again shortly after I replace it?
