Clutch for bolt-on LS1 Camaro
So I have decided to only do a bolt-on build for my Camaro. I should not need a very heavy clutch at all since the car will only be making roughly ~350whp. I have given the LS7 clutch some thought, but heard a lot of complaints about how heavy the LS2 flywheel is. Any clutches I should be looking into? This is a budget build FYI. Thank you.
Check out diamond clutches i have a stage 3 in my camaro, a buddy and i just put in a stage 2 in his trans am and they work great. Look at the stage 1, it would be perfect for you. diamondclutch.com
I was pretty hard on that clutch.Alot of track times. I had put a moser 12b around the same time,1.6-1.7 60 ft,s all day no slipping or missed shifts. After the h/c I went with a puck style clutch, it was great for holding power but hard to drive at times.Alot of chatter with some weird sounds.
