v6 manual trans fit a v8?
i have some other threads on here, i recently had some head/gasket issues and will not be fixing my v6. so im looking for all the information i can find on v8 swaps, also there is a donor car but it is a v6 as well, it does have the manual trans and i would really love to get my hands/feet on one of those and get it into my car. any info would be appriciated
damn, thank you very much. grab pedals, wiring, and interior pieces then. thank you much. anything else? all info is greatly appriciated. my 2000 v6 just crapped out, the local salvage yard has a 99 v6 model with manual trans, engine missing though. i have been getting mostly interior parts but will be checking on the wiring, im sure the pedals are still there.
- either 1st drive/driven gears are reduced/increased in dia. and tooth count
- or the main drive (input to countershaft) are modified similarly.
I know of someone with a T56 adapted to a T-3800. Anything is possible and adaptable. However, when you can pick up a good used trans. for a few hundred $, it doesn't make sense to spend much more $ adapting something unless the life of it is significantly reduced.
