clutch rattle...normal? opinions?
Noticed today when I shut the car off a rattle from the clutch.. Car was in neutral, clutch disengaged (car doesn't do it with the clutch engaged). Searched around a bit and found some different things, some info suggested it is normal for some of the M6 vettes. Just coming here to get a second opinion... let me know what you guys think.
Car has a stock clutch, less than 20k miles on it.
First two times, clutch was disengaged. The last time, clutch was engaged, and no rattle.
not entirely sure how to embed tinypic video..
http://tinypic.com/r/ar1aw/7
Moderator
Received 1,835 Likes
Originally Posted by chrysler kid
Throw out bearing on the end of the slave. When it gets really bad it will make noise all of the time except when you push down on the clutch pedal and it contacts the clutch pressure plate
I thought the T/O bearing was only doing work/loaded with the clutch pedal in (clutch disengaged). I had frequent T/O bearing failures on an old Mopar 4 speed (833). It eventually made considerable noise with pedal pushed in. Never a sound with clutch engaged. That trans had to have some type of clearance/misalignment issue I never found.
It's typically not an internal bearing that actually fails, if I recall the ls1 throw out bearing is a pressed in piece that rests on the end of the slave. The case suffers damage and you can hear the bearings rattle inside the case. When the slave pushes it into the pressure plate it pushes the case back onto the bearings like it should normally be seated and the noise goes away. I could be mistaken though but that's what I remember
I have a buddy with a lt1 and a buddy with a ls1 car (t56...) Thiers rattle as well. I just did a swap so my sound deadening is out. it sounds terrible on my car because of it (me paranoid about any noise). My throw out bearing is new as well as the one on my buddies ls1 car. My mind is at ease.
