C5 LS1 Torque Tube Bearing Snap ring
Trying to get a part # for the Large Snap Ring that holds the rear drive shaft bearing in the rear of torque tube on a 04 C5 with 6spd ? or if anyone knows where one can be Purchased, Any info would be Appreciated ? Apparantly I do not need the snap ring that is basically what holds the bearing on shaft, What I am trying to find out is what holds the whole bearing case in torque tube, There is 3 bolts in bearing housin but no one seems to know what they are for, I would think they go into a collar that fits in torque tube or they are used for a puller to get shaft out of tube? Anyway here is a pick of rear of shaft if anyone know's it sure would help.
Thanks Perk
Thanks Perk
