Duralast slave cylinder.. anyone?
a new slave with release bearing is only 69 dollars at autozone.. I went to advances site and there tech*** something brand was 71 with countless bad reviews of going out every other month.. I know duralast makes good OE ****.. has anyone run a duralast slave cylinder without problems?
go to your local autozone and if they have one on stock look at it. If it has an AP cast into it and is made in mexico and not china it's the same thing as a GM slave.
The slave cylinder to avoid is all black and has no numbers or letters cast into the housing. That's the cheap Chinese one..
I'd personally avoid a Duralast brand slave. I just bought a "Z06" slave and have my mechanic install it, and it's awesome. You get what you pay for. I'll try and get you the part number on the slave I had installed if you're interested.
the "duralast" mexico one is OEM, ill use that.
Lets see what this ap stamp looks like and also the knock off chineese one someone else mentioned earlier. Just bought one, want to mmake sure its the good one. Says it came from mexico.
I found out the lifespan of my "perfection" piece this week
it lasted about 12k miles before it gave up and I couldn't get it into any gear at all, the clutch I got from them blowing out after 5k miles should have been the first hint to replace it
I installed a duralast AP one and so far so good
After reading this thread, I decided to online order a new Duralast clutch master cylinder and slave cylinder. The master is made in Mexico but the slave cylinder is made in Taiwan ! I'm not happy about that and I'm probably going to return the slave. What other options do I have that aren't Taiwan or even worse, chinese made??
I've been researching this forum for the last hour and its starting to look like the GM slave cylinder may be the way to go.
http://www.tickperformance.com/gm-sl...or-ls1-f-body/
Can anyone tell me where this part is made?
