Clutch Sticking to Floor
02 WS6
I went to the track and could not get my car into 3rd gear and the clutch needed to be pumped every time I punched it. I was told to change out the slave cylinder and master clutch cylinder. I did and now I can get into third but the clutch pedal still sticks and I have to pull it up with my foot and pump the pedal to get pressure back. Please Help. Whats the problem.
Fluid looks a little dirty and yes only under high rpm. I did not do the drill mod because I thought the Tick Performance part would fix this problem. Yes it is the stock clutch and the car makes 550 hp and 470 rwhp.
LS1TECH Sponsor
...and yes, our Adjustable Clutch Master Cylinder Kit eliminates the need for the drill mod, as it includes a stainless braided, heat-wrapped unrestricted line, seen here: http://www.tickperformance.com/tick-...or-ls1-f-body/
Best of luck!
