Can I use heater hose to replace my reservior line?
I dont know about that,,,,, Heater hose is rubber, the reservoir hose is rubber, Brake lines to the caliper are rubber, Dont know if there are different compounds but I dont think the brake fluid will eat the hose, but I am not sure. I know the reservoir hose is really thin, and heater hose, even some vacuum hose is considerably thicker.
Just grab some appropriately sized fuel hose from a local auto parts store. Most of them will say on the package what it is compatible with but most automotive grade hoses that work with gasoline also are fine for brake fluid as well.
Sorry, this is not true.. Only rubber hose listed safe for brake fluid or silicon hose should be used. Fuel safe hoses can still sweat (best case) or dissolve (worse case) in the presence of brake fluid. If the hose dissolves, it will take out the seals in your master, your slave, or both...
