Just ordered a McLeod rxt clutch and steel flywheel, What comes with the kit? I just purchased the McLeod clutch and flywheel, it should be a week before i get it. What comes with the clutch and flywheel? and what other upgrades should i get while im in there? thanks |
any ideas |
You get the flywheel, discs, floater plate, pressure plate. You'd be smart to install a new slave cylinder while the trans is out. ARP flywheel bolts are an upgrade if desired, but not required.....the stock bolts will work fine. You'll love that RXT, I beat the snot out of mine with 650+rwhp and it laughs in my face. :D |
Originally Posted by jmm98LS1
(Post 16166977)
The factory GM slave. You can pick them up at certain auto parts stores. Look for the "AP" stamp on the base |
© 2024 MH Sub I, LLC dba Internet Brands
