McLeod bell housing owners come inside!!!
Old 03-08-2012, 03:19 PM
jt76's Avatar
Default McLeod bell housing owners come inside!!!
I just picked up a Mcleod bell housing. I know about the issue with having to grind down the back of the oil pan and what not to get it to fit. Can you run just the bell housing without the motor plate?
Also, mine didn't come with any hardware (idk if it wasn't included or slipped through the 5" hole in the box thanks to shitty FedEx). I contacted Mcleod 2 days ago about the hardware and have received no reply. Does anyone know the sizes of bolts i need and what not? Thanks for any help.
Old 03-09-2012, 08:36 AM
jt76's Avatar
to the top
Old 03-09-2012, 07:18 PM
ls2 bait's Avatar
The hardware that came w mine was junk/ wrong so I just went and bought new stuff anyways. Id just do that. I had mine on for a while with no plate due to time constraints and needing a diff rear cover to make it work.
Old 04-15-2012, 02:17 PM
jt76's Avatar
Bump! Putting everything together today.. does anyone know what size hardware i need??? OR will the stock hardware work? Thanks
Quick Reply: McLeod bell housing owners come inside!!!
