New Clutch/Tick Mater & still wont disengage!!!!Please help
Hey guys car has been down for over 2months, Put a new clutch from Texas DriveTrain performance, his clutch brand..a new slave and new tick master.
I have been bleeding it in every way i can think of, mitivac, and the standard crack the bleeder while clutch pressed down to the floor.
Car still wont go into first at all, if i start it with the car in gear then it will try to jump forword.
Im so lost right now, anything would help please and thanks
Where is your clutch pedal set at? Try setting it close to the brake pedal and see if it goes into gear smoothly from there. It took me and a friend 5-6 times of bleeding before we had pedal pressure. Make sure the res cap is on and that its fully every time you bleed. Make sure the quick disconnect is on tight and the bleeder valve is closed after bleeding
