Ist gear locked
Ist gear locked
Need some help, My tranny has a fresh rebuild, the only time that is on it is at the track, with about 4 passes. I have been backing it out of the garage weekly to work on the car, Yesterday was no different, reversed out of the garage, put it in 1st and shut her off. Went to back it up a little more and it is jammed in 1st gear and will not budge. I tried revving the motor, revving and trying to pull it out of 1st the same time and no luck, What the hell happened?
What happens if you put it in first gear and rev the engine? Does thw car creep forward? Does this issue change if you pump the clutch pedal? If it worked, and now it doesn't, then it could easily be relative to a hydraulic issue. Do you notice any leaks?
everything is brand new, app 5 miles on completely new setup, I had been backing the car in and out of the garage with no problems. Clutch works as should, no creep, still goes fwd in 1st gear, but does not come out with the engine on or off, revving does nothing. I believe it is something internal of the trans, have no choice but to pull it...
