Fastest Six Speed List
Old 10-18-2017, 07:16 AM
  #381
stevieturbo's Avatar
Originally Posted by thirdgenbum
acceleration under power should not be happening in the OD gears. change differential gears for maximum engine RPM through the traps (whether that is 1/8, 1/4, or 1/2 mile) in 4th gear (1:1). those gears are just too small for that sort of abuse.
I hear ya, but creating a 200mph capable 4th gear, would make the car totally useless at anything else.
Old 10-18-2017, 08:47 AM
  #382
GTA91's Avatar
I agree with Stevie it would be nice to see quick detail on the transmission type. After all, this is the fasted 6SPEED list. lol
Mine is a faceplated fbody T56. (also cryo'd, REM polished, and Viper mainshaft) and I basically copied Ray Bulach's old build. Its held up well to abuse in a heavu nitrous car and I really need to put a pump on it.
I have multiple Drag Week buddies pushing 1000+rwhp through bone stock Magnums and beating on them and they're not even phased. Impressive as hell if you ask me.
Old 10-18-2017, 11:48 AM
  #383
See those sort of reports about the Magnums is what gives me some confidence they might be the best value option. Obviously it doesnt include 5th...but still good info.
I ran my 9's on a stock geared T56, cryo'd with Viper mainshaft, still syncro.. Not a huge ask really. I later had 1-4 faceplated...but was surprised that the synchro slider exploded in 5th. I had always expected either the teeth to go, or the dog teeth for the extension cluster for 5/6
On the stock T56 I kept as a spare, it was simply the teeth on 5th gear that went.
Old 10-18-2017, 08:42 PM
  #384
thirdgenbum's Avatar
there are days i wish i had bought a magnum, but the new gf5r laughs at what i'm doing, and will ultimately be the fastest trans for my combo without spending 10k on a trans.
Old 01-11-2018, 03:15 AM
  #385
LSxPwrDZ's Avatar
Jeremy add mine on there for now until I can improve it this spring.
Attached Thumbnails Fastest Six Speed List-a9094e9e-a00a-4155-9f68-44f6be43456d.jpeg
Old 01-11-2018, 07:15 AM
  #386
Jeremy@RPMTransmissions's Avatar
Can you put your info in the format posted in the original post for me?
Thanks!
Old 01-11-2018, 08:50 PM
  #387
LSxPwrDZ's Avatar
9.078 @ 136.08 - 1.386 - Textralia Exo Skel Twin - 370 --- S485 22psi --------- 3300 - James@ShorTuning
Old 01-12-2018, 07:22 AM
  #388
Thank you sir! Got you updated.
Old 03-17-2018, 10:18 AM
  #389
SSSTANG#1's Avatar
Had my new best et and mph last night on a very shi**y run. 9.55 @ 145.72 - 1.35 - Ace NexGen ------- 447ci --- NA -------------------- 3030 - SSSTANG
Old 03-24-2018, 09:17 PM
  #390
SSSTANG#1's Avatar
The driver is coming around now!!!�� Now I need to work on that 60’. This car has a lot left in it.
9.41 @ 147.44 - 1.38 - Ace NexGen ------- 447ci --- NA -------------------- 3030 - SSSTANG
Old 03-26-2018, 07:29 AM
  #391
Nice pass! Got you updated
Old 04-08-2018, 01:05 PM
  #392
gnx7's Avatar
SSStang with a 32mph back half gain! That thing is moving.
Is it 3030lbs with driver?
What clutch/flywheel setup are you running?
Old 04-09-2018, 06:01 AM
  #393
SSSTANG#1's Avatar
Yes, 3030 with me (190 lbs). If I can ever settle down and drive it like it should be driven, it could dip into the very low 9’s. The clutch and flywheel are Ace/Black Magic NexGen. All aluminum, 26 lbs total.
Old 04-28-2018, 09:28 PM
  #394
lazerlemonta's Avatar
10.5843 @ 130.89 - 1.5284 - 5.5” Triple Tilton - 376--- Bolt Ons/1.85 rockers --------- 3110 --lazerlemonta
2010 C6 RPM Transmissions stage 2 4.10s Bolt Ons, 1.85 rockers and a crank scraper.
Attached Thumbnails Fastest Six Speed List-0354ea63-1ba8-4ca3-b7b5-7d093d4fa39c.jpeg
Old 06-07-2018, 07:40 AM
  #395
transdam's Avatar
Vs480. 370cid. 5.64 at 126mph 1.31 60ft 1/8 mile.
Old 06-09-2018, 06:54 PM
  #396
SLP IROC-Z's Avatar
99 Z28, NA Stock LS6 crate, Most bolt ons, suspension, weight reduction, 6 speed w/mcleod rxt, 3270 race weight
Old 06-09-2018, 07:29 PM
  #397
Tuskyz28's Avatar
What tires ? Have you ever had the on dyno ? Love the launch picture!!
Old 06-09-2018, 07:51 PM
  #398
SLP IROC-Z's Avatar
Thanks!, I run a 26x10 stiff wall et drags on a 15x10. Yeah it makes 435 at the wheels.
Old 06-09-2018, 09:12 PM
  #399
HioSSilver's Avatar
Nice man...right where my bolt on ls6 was running.
Old 06-11-2018, 03:04 PM
  #400
SLP IROC-Z's Avatar
Quick Reply: Fastest Six Speed List
