master cylinder line and exhaust manifold fix!
So for past couple of months my transmission has been making a lot of noise, vibration in car, power loss, hard to get into gear etc... I've tryed bleeding several times with no luck til now! This might sound dumb as hell but my master cylinder line was out from behind the heat shield sitting a few inches from exhaust manifold, so I pushed it back behind, which added probably 4 more inches of distance away + heat shield... Then I went for a drive and right away my pedal started to feel much more firm then usual, did a downshift into 2nd ,tires busted loose for first in a long time and bam launched like crazy felt like I slapped like 50hp in mods on haha... Anyways thought id just share with u guys, I figured the line popped out when I did my motor and transmission mounts, so when u guys do those make sure to get line back in place!
