lt1 to ls1 t56 conversion
Old 07-15-2012, 06:09 AM
stevecritt's Avatar
Default lt1 to ls1 t56 conversion
I have the ls1 input shaft. Question is do I have to get a new bell housing to bold up to my lq9? or is there a spacer?
Old 07-15-2012, 12:36 PM
fergymoto's Avatar
You need to get the LS1 front plate and LS1 bellhousing.
Old 07-15-2012, 01:46 PM
stevecritt's Avatar
but I can use one from a nother car? It doesn't have to be an aftermarket one does it? they are really expensive....
Old 07-15-2012, 05:04 PM
redbird555's Avatar
you will need an ls1 bellhousing and front plate and also the input shaft for an ls1 as it is longer. you can use used parts although i would go new on the input shaft
Old 07-16-2012, 03:26 AM
stevecritt's Avatar
OK,... well I have done hours of research today, on every web sit that my Government computer would let me access and Ls1tech is not one of those, go figure. I have the input shaft, I'm gonna get a
front plate - 200
Bell housing - unkown.. only ones I can find are new and for 500+
ls1 clutch and flywheel - mclouds $1100
Do I have to have the ls1 master and slave cylinders?? cant really find clarification on that one.
also do I have to have the ls1 pedal set up? I found a few that say yes and other that say no.... anybody know for sure?
Old 07-16-2012, 07:26 AM
redbird555's Avatar
I'm not sure about master cylinders however they should probably be replaced as chasing down issues with used hydraulics is just a pain. you will need an ls1 slave also which you can get from autozone because it is the same part as a gm one. as far as the bellhousing goes you can usually find a used one on here for around 150 keep in mind you can also use an 04-06 gto bell but you will need the gto starter then as well.
Quick Reply: lt1 to ls1 t56 conversion
