Truck's master cylinder
I want to go with a Twin Disc clutch and the only problem in my way is the stock master cylinder. Since there isn't a straight solution for that. Does anyone know how I can choose a proper wilwood master cylinder since a lot with different bores and strokes are offered. All I know is that factory bore on the truck's master cylinder is 0.69mm. I do not know about clutch hydraulics and I would really appreciate all input.
If someone out there can modify a truck's master cylinder for the right price, let me know.
Thanks
Thanks
You think my problem is with my lines or maybe need a shim?
I have the stock lines
Its good wheb I start it but when I beat it a little. It doesn't shift until it cools down a bit. My tranny's cluster is whining and I'm not sure if this is the cause of the problem or if my hydraulics need bleeding or service.
Guide me on the issue please
