Lt1 and t56 grinding in 1st and 2nd gear
Hey wondering if you guys could help me out with a problem I'm having.
I have a lt1 and t56. Just put a new prebled master cylinder, clutch, and pilot bushing. When I installed the pilot bushing it was slightly dented around the edges from hammering it in with socket but looked good in the center.
Ran good for about 600 miles now out of no where my trans is grinding in 1st and 2nd gear. It seems like the input shaft keeps spinning for a second before I can shift into the gear. If I wait a second for it to slow down it shifts into gear with no grinding. Is it possible that the input shaft is binding to pilot bushing? Or is clutch not fully disengaging? Also lifted up back tires and depressed clutch pedal with it in 1st gear and tires spun about half a rotation when i reved to 4000 rpm.
Do you think it's pilot bushing related or hydraulic related?
Or transmission related?
I am looking forward to your response.
Thank you!
Thank you!
Thank you
Save the manuals!
No I didn't measure clearances I'm going to look into that. I put a new Valeo clutch kit that I had laying around for a few years the throw out bearing was in the kit. I also put a prebled clutch master and slave cylinder from perfection clutch. So it's not adjustable. I'm going to look into the clearance thing you are talking about.
There's a lot of other information on the internet and some videos on how to do this. It's a little bit of a PITA and you'll need to drop the transmission again - and if you need a shim, you'll need to wait for it, but you'll know for sure.
