recipe for 406sbc T56 without adapters?
I have an external balanced 406sbc which is limiting my flywheel options for mating my new LS1 T56 to it but I think I have comeup with a recipe that I have not seen yet.
-2 peice mear main block (flywheel mounting surface is .400 further from block than LS1)
-bellhousing pattern is the same for 5 of the 6 bolts so they can be bolted together without an adaping spacer as long as clutch clearances can be worked out.
- from what I have gathered, an LS1 flywheel is around .815-.870 thick.
- SBC flywheel is typically .850-.960 thick so chalk it up to about .100" difference. Together with the .400" from the crank mounting distance we are up to .500" less distance between the pressure plate mounting surface and the transmission.
- In this thread, (please see post #8 for the pictures) https://ls1tech.com/forums/manual-tr...questions.html it looks like the difference between the LS1 slave and the CTS-V slave is around .5" maybe greater.
With the posslibe addition of a spacer or 2 behind the slave cylinder, does this look like a feasible plan? I will be using an 11" clutch and diaphram pressure plate designed for a BBC with 26 spline disc since I cannot find the correct flywheel to allow me to bolt an LS1 style clutch to a sbc 168t flywheel.
The only part I can see posibly possing a problem is the engagement of the splines on the clutch disc because it will be operating roughly .500" closer to the trans than it would have behind an LS1 (made possible by the shorter CTS-V slave. Can anyone confirm if this will or wont work? Anyone know the thickness of the spacer normally used behind the slave in question? or the compress height of an LS1 slave?
thanks
thanks
Usually, an LS1 (2002 F or GTO) trans. with it's original bellhousing & slave needs spaced away from a SBC to operate a Gen I push clutch. With you saying a spacer behind the slave is the answer which contradicts that, you're going to want to measure some more at the parts store rather than online. No offense. I love this stuff and you're on the right track, but the most accurate person to mock it up is you.
I take it you're wanting to use a hydraulic clutch system? There's an adapter plate/spacer that allows a ls t56 to bolt up to gen1 bell and use all the gen 1 flywheel/clutch/TOB. I'm using this on my C10, but utilizing the mechanical linkage I already have. You could maybe fab up a mount for an external slave to use with the gen 1 push style fork?
This picture is taken from the link I posted above.
CTS-V slave on left, LS7 slave on right
Anyone know the thickness of the spacer required on the CTS-v slave to bring it up to the same as the LS7? Is the LS7 the same height as an LS1 slave?
