LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Manual Transmission (https://ls1tech.com/forums/manual-transmission-14/)
-   -   Something's wrong...need help (https://ls1tech.com/forums/manual-transmission/166040-somethings-wrong-need-help.html)
-Q- Apr 28, 2004 08:51 PM
Tonight on the way back from work I hit a huge pothole coming down the off-ramp of the interstate. I had the clutch pressed in when I hit the pothold, and the pedal stuck down until I could get the car into a parking lot. When I pulled up on it a little, it came free, but now it's making a popping sound when I reach the top of the pedal travel (it also catches a little when it pops), and I hear some kind of rattling sound when I turn the car off. The car will still drive, but I'm worried about it. If anyone has experienced this before, please let me know. Should I take the car to the dealer to get it looked at? It's not under warranty anymore, and I'm new to this area so I don't know who else to take it to.
wrencher Apr 28, 2004 08:59 PM
Is the noise inside the car?
You might have broken the return spring on the clutch pedal.
-Q- Apr 28, 2004 10:08 PM
The noise is definitely inside the car. The "pop" that the clutch pedal makes occurs at the same time I feel the pedal "catch" when you let it almost all the way out. How hard is it to fix the return spring?
Camaroholic Apr 29, 2004 07:09 AM
I seem to recall guys breaking these before.
I don't think replacing it will be a big deal. Remove the panel under the steering column, and then probably just a pair of needle nose pliers for the spring. Shouldn't be too bad. :)
-Q- May 1, 2004 10:56 AM
Turns out it was the return spring. I pulled the bottom of the dash off today and three pieces of spring fell out. I'm off to get a new one now; I can't believe the damn things are $40!!
© 2026 MH Sub I, LLC dba Internet Brands
