SPEC Slave/throwout shim question.....
SPEC's tech office is closed today. Measured according to SPEC's directions.
Measurement "A" , the distance between clutch fingers and face of bell housing is 2.0925" (2-3/32").
Measurement "B" , the distance from face of throwout bearing to the transmission face is 2.000"
Their sheet allows for measurement "B" to be between .175" and .225" LESS than measurement "A" and any more than that you need a shim. Since I am under the .175" measurement "A" I'm assuming I need no shim.
My question: Is there an issue with it being .0925" when the window is .175" to .225" ?
Thanks for your time
Mike
Mike
