New Transmission Alternative? 300zx Transmission - LS1TECH - Camaro and Firebird Forum Discussion
Notices
Old 02-13-2015, 02:16 PM
Default New Transmission Alternative? 300zx Transmission
The 300zx z32 RS5R30A 5 speed transmission can be bought for WAY less than our t56's are going for now-a-days ($300 give or take), and are just as strong, if not stronger.
Who here would use this transmission behind their LS if the kit to make it possible was available at a competitive price?
littlereds10 is offline
Old 02-13-2015, 05:31 PM
Project GatTagO's Avatar
Project GatTagO is offline
Old 02-13-2015, 05:32 PM
Ratios don't look that great:
1st: 3.214
2nd: 1.925
3rd: 1.302
4th: 1.000
5th: 0.752
Rev: 2.275
Old 02-13-2015, 06:24 PM
jmd
900 for his adapter plate and flywheel plus a clutch you may have to source separately for the disc and you're guaranteed to need a driveline for your S10 and you get one less gear. Plus, ratios 1-4 similar to a Fox body T-5 with an OD that is irrelevant to an engine thhat can pull more OD.
I would consider it but I wouldn't go out of my way to source one. The real cost (not your apples to oranges bit) isn't far apart and there is no tangible gain.
jmd is offline
Old 02-14-2015, 01:39 PM
Would it be more ideal if the adapter kit was closer to 700 or 800? I May know someone who can manufacture a kit for a reasonable price.
Old 02-14-2015, 01:43 PM
Btw the stock 300zx clutch, starter, and slave/fork is used. And it's not going in an s10, but it could be. I don't have a formal quote yet but 800 for the kit and 300 for a used trans sure beats the price t56s are going for
Old 02-14-2015, 02:22 PM
Seems like a stout piece, but I'm really not a fan of the t-5 style ratios. The deep first gear is useless in my opinion, with LS engines that produce good torque.
79_T/A is offline
Old 02-14-2015, 03:38 PM
We've been kicking around the idea of reproducing R154 gears for the Supra so people can have an affordable alternative to some of the more expensive units like the T56 in the import conversions.
AMP-D is offline
Old 03-30-2015, 11:23 AM
Who would buy the kit (flywheel, bellhousing adapter, and pilot bushing adapter) for $750?
Old 03-30-2015, 02:14 PM
blackandgold's Avatar
I wouldn't. I don't like the ratios, 1st gear looks like it would be useless, especially with 4.11s in the back...And 2800RPMs to do 70mph on the highway...
blackandgold is offline
Old 03-30-2015, 08:19 PM
Yeah those ratios are not good for an LS1 powered car at all.
79_T/A is offline
Old 04-01-2015, 03:12 PM
SSCamaro99_3's Avatar
Are T-56's really that expensive? Seems like after all the adapter stuff you are most of the way to the real thing.
SSCamaro99_3 is offline
Old 04-01-2015, 04:15 PM
Also a good point.
-Used z32 5-speeds are 700-1k for a used unit on ebay + 750 for the kit
-A used t-56 goes for around 1400-1600 in the classifieds here
So either way you spend around 1500 for a used trans that may or may not need a rebuild...If everything for a z32 5-speed could be had for under 1k, I could see it as a viable cheap option. Who knows people may buy it though. I think within the next year or so the aftermarket will pick up slack building parts for the t-56 and this may be a non-issue.
Now with all that negativity out of the way, I'd love to see someone slap one of these in purely for the cool build thread!
Old 12-18-2015, 07:40 PM
Just thought I would bump this thread to say that we now have a much cheaper option if one wanted to run a Z32 trans behind their LS. This kit is $600
http://www.crossmembers.com/shop/con...kit-p-453.html
I/m going to get a complete Z32 trans setup for $200 at the local yard this weekend.
Adapter $600
Decent TT clutch $200
looks like I can get this setup together for $1k
Can I make up for the less than ideal ratios by replacing the diff with a certain ratio?
It's going into a BMW 3-series with 17' wheels
Thanks
sebasc300 is offline
Old 12-18-2015, 07:51 PM
Adapter $600
Thanks
Thanks for the bump! I forgot to post up that we released this adapter kit. I'm in the process of developing a 350z transmission adapter now
Old 12-19-2015, 03:39 PM
The Nissan box as strong as a T56 ? I really doubt that.
More options are always good for swaps though, especially as the T56 is quite big and heavy for those that dont need or want 6 gears or such a strong/heavy box.
But lets face it...the T56 is good value, they just bolt on, no aftermarket parts are needed and everything is available off the shelf with no cocking about.
They just make sense.
For lower powered cars, a T5 isnt hard to fit
stevieturbo is offline
Old 12-31-2015, 04:12 PM
There are tons of reports of the Z32 transmission withstanding 800+ whp in TT Z's, reliably.
I know they don't make near the amount of low end torque that an LS will put out so it remains to be see what they can handle when paired with an LS.
The gearing isn't a huge deal breaker to me and many swappers because we have to upgrade our diff anyway.
I plan on running mine behind a stock LY6 before I slap on an LSA supercharger. It's going into a 3200lb BMW that will be daily driven on the street so I think this transmission will hold up to my power goal without breaking the bank.
I will be purchasing the transmission tomorrow at the local U-Pull-IT yard for a whopping $90... Gotta love those 40% off days.
Old 10-25-2017, 04:17 AM
Has anyone ran the z32 transmission? Im running one but after my motor warms up the starter has issues cranking the motor does have higher compression. Has anyone found a high torque starter for this setup?
Frod629 is offline
Old 10-25-2017, 05:10 AM
Might help if you stated what starter you were using etc.
Old 10-25-2017, 01:48 PM
Im running a z32 starter
Frod629 is offline
Quick Reply: New Transmission Alternative? 300zx Transmission
About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
