Oh no... lsx/t56 mid engine questions..
Old 04-14-2015, 07:11 AM
RecklessV's Avatar
Just bought the fbody mid plate. I read somewhere that the c5 input shaft was the same as the fbody one. So hopefully the midplate is the last piece of the puzzle. Then figuring out the shifter completely.
Old 04-14-2015, 05:41 PM
garys 68's Avatar
I was looking at their website, I didn't see much on the drivetrain. Any links to what you're talking about?
Originally Posted by jmd
I thought it was pretty obvious (from other pictures of the Locust Plethora) there was something in between the front trans. case plate and the bellhousing. With that, it would make sense they'd just retain the Vette front case plate.
Have you made any headway in implementing shift linkage?
Old 04-15-2015, 12:08 PM
RecklessV's Avatar
That's the plethore drivetrain, it's the only pics I've seen. You can see the aluminum adapter between the bellhousing and transmission. I already bought an fbody mid plate so I'm going to change the c5 one for the fbody so it all bolts up with no adapter.
Old 04-15-2015, 12:14 PM
garys 68's Avatar
Yeah, I was thinking it would be possible without an adapter.
Thanks for being the guinea pig on this. I've been considering something similar for a while. Maybe even a turbo gen V V6 for added clearance.
Old 04-17-2015, 03:16 PM
RecklessV's Avatar
So this is where I'm at. That's the c5 t56 with the fbody mid plate. The transmission is in neutral and there is a gap of about 2 1/2". The midplate is pushed all the way into the longer shift rail. I know I'm going to need to cut it down. Does anyone know how much of the shift rail is sticking passed the housing on a fbody t56???
If I cut off 2 1/2" then I know it'll sit flush, but I basically wont be able to get into 2/4/6. So I'll need to cut more, I'm thinking 3" ?? I'm going to rebuild the hole tranny but I don't want to get a new shift rail if I don't have too. Any ideas?
Old 04-17-2015, 04:25 PM
garys 68's Avatar
Isnt there a thread in this forum on converting a vette T56 to f body?
Old 04-17-2015, 06:46 PM
RecklessV's Avatar
Only threads I've read, say to use an fbody shift rail. Since I'm not using a tailhousing, I'd then have to cut the backend of it. So might as well figure out where to cut mine.
Old 04-17-2015, 11:42 PM
jmd
jmd's Avatar
You have a vertical detent, reverse lockout, horizontal detent, rail bushing engagement, and shifter location to figure out. If you cut the front end off, that's fine if it's still fully engaged to the front plate bushing while in 1,3,5,R. But you lack a shifter position.
The most straight forward way to do that and keep everything functional except for reverse lock-out is to get the aftermarket lever for center shift. To keep reverse, you could weld a shifter pad to the tailhousing and make a rail that goes to it. You still need to run a shift rail to the cabin.
While informational, the conversion of Vette T56 to GTO write-up doesn't address what you're doing.
Old 04-18-2015, 03:15 AM
stevieturbo's Avatar
Select any gear where the shift rod is in it's most forward position, then cut it so it doesnt foul the base of the hole in the front plate.
Old 04-20-2015, 08:32 PM
garys 68's Avatar
What's the measurement from the block to the drive axles?
Old 04-22-2015, 05:15 PM
RecklessV's Avatar
There it is.. all bolted together.
The input shaft sticks out exactly 1" passed the bellhousing, is that good enough to reach the pilot bearing?
Also, I had to cut exactly 3" off the shift rail in the front to bolt the fbody mid plate on.
Question, I'm using the c5 input and bearing that went to the original mid plate, but when I tighten the bolts down, it clamps on and doesn't let the input shaft spin... are the fbody bearings thinner??
And it exact 30" from bellhousing to center of the axles. So basically 50" from axle to front of the engine, minus accessories. Pretty long but no worries.
The shifter will be going in the mid shift location, and I'll be using the kiesler socket shifter adapter. I thinks it's like $120 from summit, I havent ordered it yet.
All in all I'm pleased so far, unfortunately; when I took apart the trans, I noticed that it will be needing a complete rebuilt but atleast I can start building my tube frame now.
Old 04-22-2015, 07:04 PM
  #32
Behind the outer race of the front bearings inside the front plate there are shims.
You will need to shim these to apply suitable pre-loads to the bearings.
It may simply be a case the shims are too large causing the tightness
Does the input shaft move at all, in any direction ?
Old 04-22-2015, 08:16 PM
  #33
RecklessV's Avatar
Ahh that's right!.. I even transfered over the shims. I completely forgot that i did . I'll take them off and see if it helps. Thanks!!
Old 04-24-2015, 09:59 AM
  #34
garys 68's Avatar
Nice job. Could you do a write up with list of parts (part numbers) and more complete listing of mods required. Looking forward to seeing the shifter.
Old 04-25-2015, 02:03 PM
  #35
RecklessV's Avatar
I don't have any part numbers on hand but it's basically...
Bellhousing - ls1 fbody camaro
Mid plate - ls1 fbody camaro
C5/C6 t56 and differential
Move the shift rail to It's outer most location (1,3,5,R gears)
Then cut exactly 3" off the shift rail.
Install the fbody mid plate on the transmission, using the bearings from the c5/c6 midplate (don't use the shims)
Now the fbody bellhousing will bolt up ( since it doesn't have the same bolt pattern as the c5/c6 torque tube)
Bolt it all together and done!
I know not much of a right up, but it's pretty straight forward. I haven't done the midshift conversion yet, but I'll post it once I figure it out and I'll be making a custom cable shifter bracket so I can move the shifter into the cabin. But that won't be happening until I start building the tubbed frame.
Old 04-25-2015, 05:25 PM
  #36
You will still need to install shims correct to your box build for both the main shaft and the cluster gear shaft
Old 04-25-2015, 11:06 PM
  #37
RecklessV's Avatar
I'm guessing fbody shims should work? I need to find out if they are different from the vette ones.
Old 04-25-2015, 11:26 PM
  #38
jmd
jmd's Avatar
http://www.thegearbox.org/catalog/it...17/3508273.htm
Same shims for T56 across the board.
Old 04-26-2015, 04:28 AM
  #39
The shims will probably be same diameter, but obviously you need to measure what is needed for your setup in terms of shim thickness
Old 07-24-2015, 01:54 AM
  #40
Burning Oil's Avatar
Default Very cool
I am going to be doing exactly the same thing. I have all the parts needed and have been searching for hours to find this combo in hopes that someone had done it, so thanks for posting.
One additional thing I'm also going to be doing is machining what I'll call "transfer cases" they will be chain driven like a chain drive transfer case in a 4x4 (imagine that ) one for each side of the differential outputs. The Tcase will off set the power output to the half shafts further forward close to the bell housing. The type chains I have in mind are from an old 67-72 Cadillac Eldorado FWD with the TH475 trans.
This will allow for a shorter wheel base and a better looking design IMO.
Pictures just for concept. I would make an enclosed/lubed version similar to bottom picture.
Oh no... lsx/t56 mid engine questions..-chain-drive-differential.jpg
Oh no... lsx/t56 mid engine questions..-transfer-case.jpg
Quick Reply: Oh no... lsx/t56 mid engine questions..
