What size master cylinder do I need?
I bought a Monster Clutch kit with a GTO slave cylinder. My old hydraulic clutch had a 1-1/8" bore diameter Wilwood master cylinder. Anybody have an idea what size is needed for the new slave cylinder or what size the factory used?
I have at least 1" of travel. I called Monster Clutch and they told me my existing 1-1/8" master cylinder would work. I thought I recall reading the factory used about a .875" bore, which would mean I am pumping one heck of a lot more fluid through than originally designed for.
The original slave cylinder was an external version off a Dodge truck and it had about a 1" or larger bore diameter.
