Go to brands for pressure plates?
Building a ls2 for my e36 bimmer and going to be running a hybrid tranny setup with a t56 bellhousing and 350z 6spd behind it. The swap kit comes with the appropriate clutch disc to match the input splines on the z tranny, but I'll need to source my own pressure plate and flywheel. Being as I'm not to familiar with lsx clutch kits and what to consider good or bad, I'm looking for a little guidance from the page.
Thanks in advance.
Thanks in advance.
I am a big fan of the LS7 clutch design. I've used it in two different builds and I really like how it works. The downside is that it's very heavy,although using an aluminum flywheel will help that.
Andrew
Andrew
LS7 clutch seems to be the same, but the flywheel designs are different between LS1/6 and LS2/7, the former is flat, while the latter is stepped.
Andrew
