at wit's end with t56 reverse issue
a bit over a month ago..i started a clutch/hydraulic swap in my 98 formula
new slave, master, clutch, and flywheel
after I pulled the trans..the input shaft had ALOT of side to side play..i found this was due to the pilot bushing being worn (worn is an understatement really)
so I assumed really it was the input shaft bearing..so I ordered a new bearing/race and shim kit..removed the front plate from the trans an replaced the parts...put it all back together and figured I was good to go (everything was aligned and where it needed to be)
I installed everything and got it all buttoned up/bled/etc yesterday
I got in the car to back it out of the garage..have good clutch pedal..put it in reverse..feels good...slowly release the clutch and get the most god awful grinding noise from the tailshaft area I've ever heard
I have NO idea what the hell happened..i have never had any problem with reverse and after all the problems I had with this job (that should have been a reasonably simple one) I can't think straight enough to figure it out
if anyone has any suggestions or ideas of what the hell happened I would be really appreciative..
It's a ripper and the stops are removed...otherwise i would have thought the same...but i can't see it being shifter related
I'll be reluctantly pulling the trans again to inspect reverse...lots of searches says it may be the fork pads...
Nothing can ever be easy
Your impression is correct...i don't know wht it would have caused damage to the pads but i'll know for sure tomorrow after it's removed from the car and tail shaft pulled
Might be a silly question but was the isolator cup still intact and in the socket? I've seen some come with the shifter when removing it. Just a thought...
Have you pulled the synchronizer assembly off to check the engagement teeth? What about the gear itself? Are the engagement teeth on it in good shape? If the trans has not been gone through before you can flip the reverse synchronizer over and use that good side. You'll have to switch the retainer to the opposite side but it's easy. While you are in there I would check the syncro ring height on 5th and 6th just to make sure they're not on their way out. It would suck to have to go into it a couple months down the road for an issue that could be taken care of right now. I would also go to some bronze pads instead of the stock plastic nylon ones it came with. If you need any help give me a call or send me a text. 817-888-4657 or call the shop at 817-625-7109/ 1-800-783-8726. Ask for Fabian. We have rings and bronze pads in stock.
