t56 with 1/4 aluminum mid plate.
The plate bolts in between the block and bellhousing correct? That means the input shaft is a 1/4 inch back out of the disc now. How do you gain the 1/4 inch back. You can't do the flywheel, that causes starter issues. Should it bolt to the back of the bellhousing instead? What is everyone doing?
