Fidanza Qwik-Rev Clutch Kit Problem
CLUTCH KIT - http://www.summitracing.com/int/parts/fiz-798572
Hi LS1TECH
i have a problem with my clutch kit and maybe someone who had the same issue could help me out because im completely out of ideas what could it be.
i've installed the clutch and flywheel about a week ago,pressure bled the slave and started the car,
the reverse doesn't want to work, the shifting takes some force and it occasionally pops out of gear when you try to shift.
ok, i've purchased a new slave cylinder and RAM adjustable master cylinder thinking it could solve the issue but it didn't. nothing has changed.
when i press the clutch i feel like there is not enough clutch in a clutch if you know what i mean. its like trying to change the gear with clutch halfway through.
Hi LS1TECH
