T56 Re-build 3-2 downshift lock out Hey having my transmission rebuilt.... Runs up through the gears just fine, try to downshift from 3-2 and it doesn't want to let you in, going slow you can put it in 1st with the clutch still depressed and it will allow you back in to 2nd just fine, If someone has had a similar problem or has any advice I would appreciate it. I tired :google: and the T56 tremec manuel.......:secret2: |
The gear itself needs replacing. Same exact thing happened to me |
© 2024 MH Sub I, LLC dba Internet Brands
