T56 magnum - tick vs D&D
I'm placing an order this week for a new t56 magnum for a fbody. The 2 company's I'm torn between are D&D and tick. I called both places and they seem to be the exact same transmission, the only difference is that the tick t56 magnum is 500 dollars more. Does anyone have any experience with either company's t56 magnums?
Thanks
Thanks
Thanks
Thanks
I didn't have a very good experience with tick when I sent my t56 to them. it shifted fine when I took it out of the car . They tore it down to put a stage 5 kit in it , ended up calling me telling me almost everything was bad and the trans was worth about $300. Being 800 miles away I couldn't go look myself. Maybe it was true maybe it wasn't. But I didn't have a good feeling about it.
Why not rpm. Seems tick and rpm are the most common . I've delt with rpm twice now with excellent result. Also rpm built t56 has the 6 speed record
D&D is a large Tremac dealer which does also modify transmissions. I bought my new T56 (not Magnum) from them in 05 and had them do a few "upgrades" to it before shipping.
I don't have any direct experience with the other two companies mentioned, can only say my experience with D&D is +
Still happy with your decision? Which shifter do you have on it?
is there something wrong with the Tremec T56 Magnum from the factory that you have to tear into it and do basically a rebuild on a brand new transmission? I thought this thing was supposed to be badass out the box? just curious because i dont know better and it seems like a lot of people go this route
I think the input shaft is a little longer, shifter position further forward and tailshaft longer requiring a shorter driveshaft.
I tried to ask this of them several times ages ago, but never could get an answer.
