T56 Reverse Lockout Wiring Quick question, I couldn't find a straight answer in the search. Does the polarization matter for the lockout solenoid? I thought I read somewhere that it didn't, but the way I understand solenoids it should matter. In any case, I've confirmed that I am getting 12V measured between the leads. I re-pinned the PCM to supply the ground. I just want to make sure it isn't backwards on the solenoid before I try to replace the solenoid itself. |
I don't believe that it matters. Andrew |
Copy, I guess the solenoid is stuck or failed then. Damnit. |
Have you taken it off for testing? I've had mine on the bench and when energized you can hear it click. If it's not clicking, it's probably done. Andrew |
If you unplug it does it block you from reverse? It's a "crash through" gate so you can force the shifter through it, but it shouldn't just be "open" to reverse if it's unplugged and working properly. In most of the 3rd gen swaps I've done I've just skipped the solenoid and used the crash through gate to get into reverse. (I had a car where they put a brake switch on to unlock it and when you step on the brakes on the freeway and downshift from 6th it would find its way into reverse at times so I scrapped that). |
(Post 19450612)
Have you taken it off for testing? I've had mine on the bench and when energized you can hear it click. If it's not clicking, it's probably done. Andrew However, I think you're right. There is no audible click when I just power the car on without starting the engine.
Originally Posted by trackbird
(Post 19454082)
assuming the reverse lock out solenoid is getting signal from PCM and does not work...than solenoid is bad. This assumes though the wiring and PCM program are right for reverse lock out I did a T56 swap in B-body and just wired the lockout to the brake pedal switch...and have never found myself in a 6 to 5 downshift buzzing reverse if my foot was on brake pedal at same time. |
1 Attachment(s) |
Im curious why you say that polarity of a solenoid should matter. It's just a electromagnet coil, right? flipping polarity would change the North & South poles of the magnetic field, but in this case it just needs to be magnetic to pull the plunger in. |
Maybe unplug the connector and run some wires into the cabin with a test light to verify the car side wiring first |
Originally Posted by Jontall
(Post 19456620)
Schematic
Originally Posted by samckitt
(Post 19456693)
Originally Posted by Nathaninwa
(Post 19458170)
Maybe unplug the connector and run some wires into the cabin with a test light to verify the car side wiring first I won't be able to get back to it for another week unfortunately. |
© 2024 MH Sub I, LLC dba Internet Brands
