Ram 10.5 dual disc clutch, can I use stock slave cylinder?
My LS7 clutch set up isn't holding up so I found a ram dual disc clutch set up I'm thinking about picking up. My question is can I use my stock slave cylinder or do I need to buy an aftermarket one to use with this set up?
Typically the clutch manufacturer would note if a different hydraulic component (slave) needs to be something other than stock
McLeod, for example, says stock for the RST or RXT twin...
