clutch pedal stop
clutch pedal stop
was looking for some info if anyone uses a clutch pedal stop so they don't over travel the clutch pedal ? I was thinking of ether fabing something up to attach to the floor with a bolt to adjust the pedal travel or attach something to the pedal its self with a bolt to adjust it.
thank you
thank you
thank you
thank you
I don't know. I was just think there is nothing stopping the pedal from over traveling. which means nothing is stopping the slave from going to far into the pressure plate.
This isn't something you have to worry about, especially if you are on a stock or stock type of clutch. If you want to potentially change peddle travel then get an adjustable master cylinder.
I have one but my whole clutch pedal assembly is custom made for my Impala SS. I use it as a stop so my neutral safety switch does not act as a stop. I set it just before my NSS bottoms out
I also have a adjustable MC (McLeod made by Wilwood) so I can adjust the "travel" of the pedal also. Works well with my McLeod Street Twin
