McLeod RST Rattle at 1500RPM under load
I just installed a McLeod RST twin-disk and Aluminum flywheel kit in my car.
Around 1500rpm, and only under any load (not neutral, coast, or idle) I get what sounds like gear chatter. It's fairly loud.
Here is a video I found of a Mustang. Same exact sound. (10 seconds and 13 seconds, most noticeable at 24 seconds)
I have seen other threads saying "its normal" because the rst is unsprung, but it certainly doesn't sound normal and needs to be addressed.
1990 Camaro Iroc-Z
LS6
TSP 228R Cam
Tick Stage 2 T56 (~4000 miles on it)
Ford 8.8 Hybrid rear axle
Stock driveshaft
1990 Camaro Iroc-Z
LS6
TSP 228R Cam
Stock driveshaft
unsprung discs do transfer more harmonics from the motor than a sprung hub will. This generally occurs more when you lug the motor.
If your situation is only when you short shift and apply gas and you hear or feel this noise for a short period while the motor builds rpm it is normal. Just shift at a slightly higher rpm
for more 411 reach out to McLeod tech direct. Billy & Lee there have always been helpful answering any of my ?'s
Twin disc clutches typically don't have sprung hubs on the clutch discs
Its Harmonics. The Engine and Transmission create harmonics that are usually get dampened by springs in the hubs of the discs when using a single disc application. When going to a twin disc application and maintaining the same overall stack height of the clutch to be the same as a single disc you generally use a solid hub that deletes the springs from the hub. When the springs are not there to dampen the harmonics you are susceptible to to the engine and transmission harmonics a certain RPM's. Not lugging the motor in that specific RPM will help, down shift to bring the RPM up.
It is when I'm in 3rd or 4th at 1500-2000 rpm (so short shift). I just cannot see a $1200 clutch setup sounding like its going to fall apart. Its a little embarrassing to drive around with. The issue isn't so much accelerating, but cruising in traffic where i need to hold a speed.
Is there any way to lessen it? Would a Crank Damper like the ATI help?
A better harmonic balancer would not hurt...but would not eliminate the engine harmonics at "x" rpm under "x" load you experience feeling them. Just carry your rpm's slightly higher before you shift
