CD009 dimensions vs. T56
Hello all.
Google is seriously failing me here. Planning an LS swap, and considering a CD009 rather than getting beat over the head for a T56. But for the life of me I cannot find any kind of dimensions, most importantly the length from bellhousing to transmission mount.....as I am hoping to be able to modify an off the shelf T56 mounting bracket (most likely for a BMW E46). Any ideas? Thanks in advance.....
Some claim they are very strong....but I know local drifters who've broke them at only modest power levels.
There are various info about them via google or youtube etc
Thanks for the pic....its a step in the right direction. In my case, just a happy little street car, thinking of jumping on the BMW E46 bandwagon. No turbo, probably just a 5.3 with a stock rebuild and an LS1 cam.
Dimensions and capabilities
Look thru the import forums. The 350z guys and the other variants of Nissan/Infiniti cars use them in all kinds of ls1/rb swaps. Toyota Supra guys are ditching r154s for them regularly as the v160 is so expensive. A brand new one from Curtousy Nissan is around $1600, just be sure if buying used you get an 06 or newer for the better synchros design. All that being said, they do hold a good amount if power and are cheap but the great rating aren't as great IMHO. Its a 6 speed with a steep first (3.48:1?) and only one cruising gear (6th). There is almost no aftermarket upgrade or rebuild parts either. I considered one of these for a while in a 240z I am building, but ultimately decided I liked the gearing of the T56 better
So in summary:
CD009: inexpensive, very tough and readily available used for even less than a rebuild on a t56, compatible with almost all Nissan z32/33/34 clutches on the market, supposedly shifts butter smooth in factory form.
T56: can be expensive used or new (especially if looking at a magnum), tons of aftermarket support for upgrades, shifters and rebuilds, accepts any gm 26 spline clutch.
Both are a great transmission with their own little quirks and issues, but ultimately it comes down to your application and intent.
So in summary:
So in summary:
So in summary:
Has anyone ever used both? If you have anything at all to add to this I appreciate it.
Thanks
