Speedtech Clutch Master Cylinder Bracket question
Hey Everyone,
Im currently in the middle of doing a LM7/T56 swap in my 1969 Chevelle, Im having alignment issues in regards to the Clutch master cylinder with using the speedtech bracket. The bracket is pointing the rod upwards towards the dash when it should be straight on with the clutch pedal. Has anyone else run into this issue?
Thanks
Thanks
