Help!! Car losing clutch pressure
Ok so the other night I was racing and when I got out of 2nd gear it wouldn't go into 3rd nor any other gears. I had to pump up the clutch before it'd go into gear. It only does this when I'm runnin it hard. I checked the clutch fluid a while back and it was pretty low so I added more to it. I'm thinking it was so low it got air in the lines. So hopefully all I have to do is bleed it. What do y'all think?
if your fluid was low....you have a leak in the hydraulics period. filling it may temporarily fix it until the fluid leaks out again
look at your MC for any signs of leaks and under bellhousing for hydraulic fluid leaking from the slave
